S smiffy911 Feb 21, 2013 #3 Ha Ha, Usually use these but sometimes too heavy handed and end up cutting the cable rather than stripping it.
telectrix ~ Mentor Arms Feb 21, 2013 #4 so practice makes perfect. i generally line up all the 6 or 8 cores and strip them all together.
telectrix ~ Mentor Arms Feb 21, 2013 #5 or you could ring 0906****** at £3/minute. she'll strip on the phone for you.
D Des 56 ~ Arms Feb 21, 2013 #6 I usually just use my fingernails It has impacted on their appearance over the years mind you fimgernails - Google Search
S smiffy911 Feb 21, 2013 #7 Yes, remember using fingernails to do this years ago when side cutters weren't as sharp
D Dazza1976 ~ Feb 22, 2013 #10 I have a set of the CK cable strippers that strip telephone cable perfectly, as long as you adjust them for use with smaller cables :- http://www.test4less.co.uk/products/495001.jpg
G Geordie Spark Feb 22, 2013 #11 smiffy911 said: Are there any good telephone/alarm cable strippers out there? Click to expand... Isn't this the sort of job teeth were invented for?
