Thanks for the reply, BS7671 does not require circuits to be upgraded to current regulations to be connected to a replacement ccu, only for it to be ascertained that they are not an immediate danger (which I would read as no C1's or C2's), GN3 even says there is no obligation to inspect or test any part of the installation!
Also found this : www.niceic.com/Uploads/File1950.pdf Guidance on cu replacement, which also says the same. interesting reading.
The document you refer to also says this:
Where a consumer unit is being replaced, additional protection by means of RCDs in accordance with Regulation 415.1 should be provided to the extent required by the current edition BS 7671, such as for:
• socket-outlets (Regulation 411.3.3 refers),
• mobile equipment for use outdoors (Regulation 411.3.3 refers),
• cables concealed in walls or partitions, where required by Regulations 522.6.6 to 522.6.8, and
• circuits of locations containing a bath or shower (Regulation 701.411.3.3 refers).
So if you are changing the CU you need to use RCD/RCBOs. You can't just avoid putting that circuit on a RCCD because it keeps tripping. And sod what the customer says, it won't be him appearing in front of the men in funny wigs if it all goes south. Do it the way it's meant to be done or walk away, simples.
Typical guidance contradicting itself, once again, this was a question about departures being noted on certificates, and talking about me being in court for leaving dangerous situation, is it impossible to have a normal conversation on this forum?
Best to get this sorted before you do any work , if you speak to the customer and explain the problem they would see your point , but if you did the job as it stands now , the client probably wouldn't bother getting it sorted
can be nightmare, personnally you could try taking some temporary 1.5/2.5 mm flex directly to fused connection unit, from board or your RCD socket, eliminating anything else on circuit see if that works, then eliminate heating circuit parts i.e pump, valves, i often take temporary flex to circuit loads eliminating other loads on circuit, to see where the problem is? but it must be RCD protected on a cu change. as said before if the fault still exists more investigation required, explain that the work must be carried out, otherwise no point in cu change. be wary of untruthful customers who say nothing is wrong, getting a quote and fixed price on board change is a good way of customer getting there faults fixed? when i first started got had on this one had to rewire most of upstairs lighting circuit due to rodent damage, customer just kept saying you quoted x thats all you getting
Where exactly is the contradiction? You have already been told by Richard Burns that your interpretation of the 'departures' section is incorrect, so I'll say it again. You can't use the 'departures' section to mitigate the fact that you have not installed, or are intending to not install, the CU in accordance with BS7671.
Wow, I mean wow. Just because your peers are telling to do a job properly and quite clearly you don't have a clue to do so, there no need to start throwing your toys. Either fix the problem (if you can) or walk away, ensuring you let your customer why. Sorry mods, but I find this kind of attitude disgusting if I'm honest.
Mate you have asked a question and been given the correct guidance by different members. Just because you may not like what you hear is not the fault of the forum.
In one part of the document it says rcd protection should be required for buried cables, but in another part (and in the regs) it says C3 can be connected to a new CCU, that is a contradiction.
The point im making is tht is not the question I asked, Im perfectly able to diagnose and fix wiring faults, but that was not my question, Im not throwing any toys anywhere, can you please explain what you mean when you say you find my attitude disgusting?
Its not that I don't like what I hear, I don't know why people are talking about me being in court when all I did was pose a hypothetical question, there's a tendency for people on this forum to assume that your totally stupid and don't have a clue what your talking about and I find that a bit ridiculous, I wonder if some of these people have conversations like this in real life?
A few questions:
Is there a fault on the circuit in question?
Do you intend putting this circuit on the non-RCD side because it will trip if you put it on the protected side?
Would you say a faulty circuit counts as a 'Departure from bs7671 regulations'? (quoted from your thread title)
Be interested to see some YES/NO answers for these, rather than waffle.
It seems you are looking for a reg you can use to justify this, when the real issue is the fact that you have a faulty circuit. Daz
The OP is very defensive. I reakon that he's actually done this already and was hoping for help in wording the cert.
tin hat on
A few questions:
Is there a fault on the circuit? Yes
Do I intend to put on non-rcd side? No but I was interested to hear peoples thoughts as it seems unclear.
Would I say a faulty circuit is a departue? Possibly yes, posibly no, don't have enough information yet.
I'm not looking for a reg to justify and I'm not waffling
Right, so you don't intend to put it on the non-RCD side. In that case you will be putting it on the RCD side. In which case, the fault will need fixing.
Daz
