L
lofty531135
Hi All.
I am not an electrician but I do know a little about electrics,I know a little knowledge is dangerous,lol.
I want to fit a pir to operate the landing light and hall light and a pir to operate the landing light.
Downstairs I have a one gang double switch which operates the hall and landing light and upstairs I have a one gang switch.
The pir's are 2 connections,load in and load out.
First question is can I combine the one gang 2 way switch with one pir or do I need 2 pir's,both lights are on the same circuit.
The second question is what wires do I use,the one gang 2 way switch has a black core going to L1 and a red core from same cable going to common and on the other switch there is a black switched core going to L1 and a red core from the same cable going to L2 and there is a link from common 1 to common 2 and another core from another cable out of the common.
Upstairs there is a black switched core going to L1 and the red core from the same cable going to L2 and the red core to the common from the other cable downstairs,I do have photos of the swiches and wiring.
Thanks in advance.
Thanks in advance.
