L
lofty531135
Hi All.
I am not an electrician but I do know a little about electrics,I know a little knowledge is dangerous,lol.
I want to fit a pir to operate the landing light and hall light and a pir to operate the landing light.
Downstairs I have a one gang double switch which operates the hall and landing light and upstairs I have a one gang switch.
The pir's are 2 connections,load in and load out.
First question is can I combine the one gang 2 way switch with one pir or do I need 2 pir's,both lights are on the same circuit.
The second question is what wires do I use,the one gang 2 way switch has a black core going to L1 and a red core from same cable going to common and on the other switch there is a black switched core going to L1 and a red core from the same cable going to L2 and there is a link from common 1 to common 2 and another core from another cable out of the common.
Upstairs there is a black switched core going to L1 and the red core from the same cable going to L2 and the red core to the common from the other cable downstairs,I do have photos of the swiches and wiring.
Thanks in advance.
i could tellyou, but then i'd have to kill you. honestly, it's a bit too complex to guess ways on a forum. you need a spark in to do it.
Ah come on geez this didn't go well the last few times did it!
Hi,Thanks for replying,what do you mean.
Think you got it right in first sentence, " a little knowledge is dangerous" or even a potential fatality.
Call a spark and be a little safer.
Just to be nice I will ask:-
Do you have neutrals at your switch points or are you using Live only PIR's?
There are no nuetrals in the wall which is why I bought the 2 conection pir wall switch,the pir's are load in and load out.
Ok, last time I post.
What does the manufactures information say about connecting there 2 x PIR's like you want?
Q. Does it say at the bottom of that said leaflet "If not sure employ a competent electrician"?
Post up your location and let an electrician do and electricians job, we train for years doing this and not just have a go. This could go wrong for you and its not worth it. Fair enough you want to have a go, I want to have a go at changing my own brake disks but I leave that to someone that is qualified. So should you.
twice you have made a comment I can only assume that you think I have been on this forum before,I can assure you this is my first time.
Righty o mate, veeeeeeeeeeeeeeeeeeeeery similar name to an ex member with similar lofty questions!
Anyway like you said, your not an electrician, so call one up and get the job done safe and soundly. Less hassle for you as you won't have to be without lights if it goes chebs up! And you can't put a price on yer own safety :)
