S
somersetsparks
On a domestic rewire i guess it is good practice to remove the old installation where applicable, without tearing the boards and walls apart. Maybe it is just me but i would not personally use any old bit of conduit i came across to pull a wire through knowing when it came out the other end i only had to chase the wall anyway to get to my destination. I would neither pull down old capping's "taped on" "tied on" metal and not even plastic for the sole reason of making sure the client got a brand new installation with everything included, ie new boxes, capping. You cant rewire an house without causing most rooms to be redecorated anyway so using easy short-cuts serves no purpose.
Maybe its just how i would approach the job.
If i were the customer, I would rather you got the cables to wherever without chasing the walls if possible, I.e less damage of structural integrety of the wall (think smashed bricks etc.) less plaster falling off and loosened from the walls etc, who cares about a stupid bit of placcy in the walls being new, if it causes £100 more worth of work? Once the cables in the wall the capping is pretty much irrelevant anyways.
As for boxes with the old placcy lugs, You have a good poin t there, most are well past there sell by date and should imo be replaced.
