Discuss Proving unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
My thinking is that the proving unit is the known supply and therefore should be used prior to any testing, I understand the veiw that how do you know the proving unit is ok, but you could go round and round this till the coos come home
That makes 2 of us mate.I just use megger
When I was an apprentice it was either a neon screwdriver or a lamp with two bits of wire,but mostly proved to be dead if the fuse was out,switched off or the lights went out.
Reply to Proving unit in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
