If the op requires help i can go through this and offer soluton using Kentec sav or alarmsense....will save you rewiring....!!!
Oh dear
Looks like your going to have to connect cables through where sounders are, and then recable all sounders from the panel
Presuming its now a finished install if its all 2nd fixed and your attempting to commission? is it going to cause much mess/damage?
Or failing that the easier option would be to install a AlarmSense panel, which will save you rewiring as mentioned above
Ok not the end of the world, 2 ways to sort this...Used Kentec sigma 2 wire panel, if using apollo smokes change bases to apollo sav, use all standard call points and smokes. and finally wire sounder reverse polarity. Second way change panel to CTEC or Kentec Alarmsense and change all devices to Alarmsense........the first is cheaper, using detection you have....but both will run all on 2 wires.
quick Kentec diagram to help.
Tazz like your drawing and how helpful you are but I really didn't mean to give it 3 thumbs up just the one would of Been sufficient. But I'll let you keep all 3 .
Fire Alarm help
edclark46,
onions1066,
