Oxo I'd prefer not to have the battery back-up but most of these locks are high security panic locks in banks and jewellers so they come pre-built with battery back-up. So an intruder can't just cut the power to open
I know but you're talking about a Karzi, and the kids lives are more valuable than money or jewels.
You seem to be thinking of 'Maglocks' thats a very expensive and unnecessary solution.
I'm sure I've done this before, the door handle on the outside is the standard wc type, the type that release from outside with a screwdriver, there is no internal door handle connected to the lock. The lock has to be a mortice type that is always in the locked position. You then need an electric keep the type that when switched off pushing or pulling against the keep opens/closes the door. When energised the keep is fixed and the doors can't be opened. The switching inside the room as per normal 2 way using standard 2 way switches.
One way i can see, is to used din rail 12v psu (no Backup), 12v electric door latch, mk dual grid switch with 1 em key switch, and push switch.
on each door remove external bar on door handle, therefore you can only open door from inside bathroom. outside each door, push switch to gain entry, on turning light on relay o/c both push switches, on turning off light doors active again, em switch on both door, releases both latches.
Why not put a microswitch in the catch well of each door manual lock. Wire each microswitch in parallel. Each door also has a maglock. If someone goes in and locks the door, the maglock on the other door also engages, all at the same time. That way you don't need to worry about light being on (if the toilet has natural light during the day) or people delaying between turning the light off and exiting.
Of course, where this falls down is if they then want to exit via the other door. Interesting problem tho...
Simple fix, feed 12/24v for maglock through a breakglass in the bathroom on the inside
Well, the other thing that I considered was pressure pads by the doors, so when you stand by the door, it undoes the maglock. but that wouldn't work for a wetroom, and may be too big, plus then the door closes behind you and locks!
Breakglass outside would be a solution, though in my suggestion only one door would unlock.
It's an quirky problem, one we'll have when we re-wire this place as one of the rooms upstairs will have a shared en-suite.
