- Reaction score
- 7,235
You will not need a battery back-up if you are going to use power-to-lock bolt, as you mentioned in your original post. If there is a power failure the doors will open. Safety first. Oxo does mention a good point You will have to use a emergency switch inside to cut the power to the doors. The switch you was going to use originally on the outside will also be your switch to cut the power from outside the room.
