Discuss 100 amp 3 way connector? in the Electrical Tools and Products area at ElectriciansForums.net
I’m sure there’s normal connector block rated at 100A, but wouldn’t trust it.
Normal “Henley” blocks are the only way I think.
You used to get dual blocks with a 5way live and neutral in the same plastic box… but maybe not available now.
Does it have to be inside the switch fuse, or is there room outside?
Like this Greenbrook 100A 2 x 5-Ways 25mm² Connector Block - https://www.NoLinkingToThis/p/greenbrook-100a-2-x-5-ways-25mm-connector-block/48024?kpid=48024&ds_kid=92700055281954475&ds_rl=1249401&gclid=Cj0KCQjwpv2TBhDoARIsALBnVnkxKf_sufjg526SZ3NCa_a_3EHA7uS9hqeMpv5sPPmZvRoxaA9saxEaAnXMEALw_wcB&gclsrc=aw.ds
Thanks all... That rs pro link does what I ask but can't see a way to fix it so will be floating in the enclosure, at least a line tap has fix holes so can be screwed to the back, which is kinda desirable at this level
Reply to 100 amp 3 way connector? in the Electrical Tools and Products area at ElectriciansForums.net
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
The seller is saying they will not upgrade the electric and it is normal to have 100 amps. However the inspector is stating it may trip often and...
Hi there. I am a doing some DIY kitchen work. In Ontario Canada, code allows either a split 15 amp multi-wire circuit or a 20 amp circuit (each...
G99 GSI-3 4.4 kw Victron inverter install with EES and batteries and installer can set the export lint if required by dno As part G99 GSI-3 you...
