Discuss 100AMP Main Panel Wiring - Advice wanted! in the DIY Electrical Advice area at ElectriciansForums.net
Hello!
Photo of panel to be attached and linked (below).
I have taken on the task to wire a new 100AMP main electrical panel. I live in Canada.
Have the permits from ESA (electrical regulatory). Want to make sure it's top shape.
Change out is from an old 100AMP Fuse box.
I have the two main legs feeding into the 100AMP breaker. The neutral is fed to the neutral bar. The GEC to the ground lug at the top.
I've used dielectric grease on connections thus far.
I would just like to confirm that this is a good setup before I start placing in the breakers.
URL:
Thanks folks!
Reply to 100AMP Main Panel Wiring - Advice wanted! in the DIY Electrical Advice area at ElectriciansForums.net
I live in las vegas nevada. I'm installing a sub panel outside that will be a 125 amps.I want to run the right wire from my sub panel to my main...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi - I am adding a NEMA 6-50r outlet in the garage for my welder. I pulled 6/3 Romex back to the panel where I will install a 50 amp breaker...
