2.5mm don't be daft you wont get them in the terms
Another DIYer.28 down lights sorry
the startup current on LED lamps can be rather high !
id split the lamps on two circuits then wire them back to a single double pole contactor and then switch the contactor with the 100m switchline run.
once you've done your cable calc for the 100m run you will probably find a 1.5mm will be sufficient or a 2.5mm for luck ! lol
