Discuss 10mm cable crimps or screw connectors in the Electrical Tools and Products area at ElectriciansForums.net
Ta I use heat shrink at present, by screw connector I'm mean like strip but beefier, when I feel like it needs a bit more security ie on the vertical I cut the brass inards from a henly and insulate
Pict
Pict
What are you mounting them in? Or are you just leaving it insulated floating?
I'm imagining just big chocblock with insulation tape wrapped round.
Correct me if i'm wrong, but there are better ways to joint a cable.
Pict
Surely you are restraining the cable suitably where it is joined anyway? Whether it's crimps, a butchered henly block or anything else you should not place the joint under stress.
personal preference, supported top and bottom of the joint, slack between on the vertical , either side and on the joint if horizontal, and I am not talking grey cable clips,
Reply to 10mm cable crimps or screw connectors in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Hi everyone We have some 10mm PCB RGBCCT strips (6 terminals/wires) being installed in the kitchen under the worktops However electrician is...
Wondering if there is a maintenance free wago for extending 10mm cables? Tried searching and couldn’t find anything. I prefer a wago to a through...
5K
I would like to reuse a 10mm cable to provide a ring circuit in an area. The cable is currently used for an electric shower, still connected at...
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
