Discuss 16th edition board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mark 21
Would a 16th edition board class as a fail on a perioic,all socket circuits on rcd side and
all lights on non rcd side,as the customer does not want a new board installing.
NO. If it was compliant when it was fitted then it is OK now, the wiring regs are not retrospective. So you need to make no comments if all tests and insp's are OK
Non RCD protection of cables in walls less than 50mm etc would only warrant a code 4 on a PIR. When it was installed it complied with the regs (16th), now it just doesn't comply with the 17th doesn't mean it's dangerous, hence a code 4.
Yep I'm going code four. Also, if there is no RCD on lighting, is there sufficient supplimentary bonding in bathroom etc?
Reply to 16th edition board in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a client with what appears to be an intermitent fault on the lighting, but trips the power. The installation has a 16th edition board with...
Hi all Any legends out there that have originals of the 16th edition Ideally in the good ol fashioned format of paper? Or failing that pdf...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
See this time after time - poor installation: new split load board on a re-wire tt installation. The main switch is not a time delay rcd. The...
