M
mongosays
Hello. Its my first time here and i am after some advice. my grandmother has had an electrical report done by an NICEIC electrician. He found quite a few things wrong with the property and has been pressuring my nan to get the work done asap!! which i dont think is right. I think he has rang about 4 times in 2 days.
The property is 40 years old and i understand that some things are probably not up to regs but wanted to double check as i have had some experience in the electrical field whilst in the forces but by no means an expert.
His report says,
bonding to gas undersized (6mm)
water bond undersized (6mm)
bonding conductor undersized (6mm) t n c s supply???
There is an older style wylex fusebox with 6 circuit breakers. He has said that we need to get that changed because the property has no rcd trip switch.
2 way lighting cable has no cpc. rewire?
there are also 2 more small fuseboxes next to the wylex. these both have rcd trip switch. 1 for shower and 1 for extra sockets. these 2 fuseboxes get there supplies from the original wylex. he says the supply cables going to the 2 fuseboxes are sized wrong. What size do they need to be? the shower fusebox turns off by a 32amp circuit breaker and the extra socket one turns off by a 32amp circuit breaker.
Apologies for the long message but wanted to give out as much info as possible.
Any help would be greatly recieved.
Dan.
His report says,
Dan.
