Discuss 2 dimable light switchs running 1 light? in the Australia area at ElectriciansForums.net
thanks for reply thats what I thought the person who has done this has wired up a landing light to 2 dimables 1 down stairs and one up. am i right in thinking the only way to do this is a dimable 2w switch up or downstairs and the other switch must be a normal 2w switch.
I dont want to hijack this thread but I've heard you can get problems with dimmers being unreliable can anyone throw some, light" he he" on this?
you can just change the dimmer at one end wiyh a fixed load modual looks
like a dimmer but its a switch if you have brass ect you can keep it looking the same
Reply to 2 dimable light switchs running 1 light? in the Australia area at ElectriciansForums.net
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Had to replace a Light Switch with a faulty dimmer. The New Light Switch is wired different from the old one but appears to work ok Can someone...
