Discuss 2 pir's with 20 lights in pvc singles in the UK Electrical Forum area at ElectriciansForums.net
G
Gav321
I'm working in an office block and am wiring the shower rooms. I have 20 lights switched by 2 pirs. I'm just wondering would it work okay if I looped the switch wire out of the first Pir through all my lights and end it at the second Pir. Or do I need a direct link from Pir to Pir.
Hi welcome to the forum :)
I'm not too sure what your asking here, you need to explain how the PIR's control the lights - does each PIR control its own group of fitting or do both PIRs control the same set of fittings?
With 20 lights as well, have you checked the rating of the PIR to switch so many fittings?
Based on info given looping a switched wire through the lights and to both PIR's will work assuming all 20 lights are on the same circuit....are they?
Yes just the one circuit. I left the first Pir with my switch wire and went through all my lights and my end of line for the switch wire is the second pir
Hi dude,the above would suggest that what you have installed,was not to any drawing,so,yes,you have imparted a modicum of design.
The method you have chose,would be ample/disastrous,depending on the type/load of the lighting fitted.
I think that's what is implied in post 8 :heart:
I didn't design it. I'm sure it's all within the regs
If you didn't design it and you have no idea of the final connected load how can you be sure ?
If you didn't design it then why are you not asking the designer or consulting the design as to how the switching arrangement for the two sensors is to be wired ?
You would have to know what fittings will be used to be able to design the circuit , especially since your talking about shower rooms here ...
It's also turning into a step-by-step installation guide request which we don't allow so I'm closing this thread I'm afraid. Discussing the pros and cons of general wiring layouts is fine and the layout you've proposed has already been deemed as plausible under certain conditions but blow by blow instructions for ongoing jobs isn't appropriate.
Reply to 2 pir's with 20 lights in pvc singles in the UK Electrical Forum area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
I have a Security Light on my patio and until recently it worked fine. It stopped working and I couldn't decide if it was the LED Floodlight or...
Hi all, Just a quick one, I want to use an ip rated light switch with a neon indicator to manually ovveride a PIR detector controlling an e27 LED...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
