My cooling fans stopped working and only kick on when the A/C is running. There are no blown fuses I have replaced the relay, temperature switch, and thermostat. I checked continuity between the relay, temperature switch and fan connectors and all read continuity threw one of the two prongs on each connector. Not sure what that means with the continuity but, thought it could possibly shed some light on the problem with someone that has more knowledge than me. Any help would be greatly appreciated!
Hi,so the fans do work,but are getting no signal to operate,from engine temperature sensors?
bypass with a dashboard switch. flick it on when temp gauge shows overheat.
sacramento
2013 Honda Civic Cooling Fan Problem
Auto Electrician Forum
Thread Tags
brady mulanix,
telectrix,
