J
Jackmcleod89
Hi I am doing my unit 204 we have to list everything we need to set up and build the drawing I have uploaded I have written a list is there anything anyone would add to it?
Please do not down load the above diagram and post on the internet. The TS is a private club and we can share/debate information within our own little community. Thanks Paul M
deleted.
yes, because i misread your pic and my comment was irrelevant. so i edited it.
Hi :)
Is there any relevance to the stuff highlighted?
Some general guidance (without doing your work for you... you've done exactly the right thing by posting what your thoughts are so far)...:
- stores might want to know exactly (or roughly) lengths of the various cables. You always need more than you think, but don't go silly!
- are they supplying tools?
- are they supplying PPE?
- you're pretty precise with most items and there isn't much scope for ambiguity (you mention steel or PVC, which is good); some (not many) of your items use colloquial names - yeah we all know what "10mm earth" is in practice, its correct term is something like "10mm 6491X G+Y (XX m)" (where "XX" is the length you want in metres)
Hope that's helpful, anyway. :)
I do have to put the length of cable and conduit I have already made my tray and trunking, we do have to put down tools aswell and ppe but I'd like help more with any other items needed to put it together and fit it
Highlighted stuff has no relevance to anything
Jobs a good 'un, then. :)
Alright, some details:
- your double socket-outlets and switched FCU, are they PVC pattresses or metal clad? I'd have thought the latter, but maybe your college use PVC? Worth checking.
- If metal clad, then I think you might have underestimated the number of brass (they're not steel usually) male bushes. You need one every time you have a coupler to an accessory or trunking, or each time you have a besa box direct to an accessory.
- a running coupler consists of 2 items - you could clarify that you know what these are where you state "running coupler" perhaps
- the fixed items, presume you don't need to put these on your list? Or do you? Again, check with your college.
