It wont be as its the level 2 exam I dont think he means the AM2Is this your AM2 practical exam?
The level 2 focuses very little on the testing aspect and is only touched on very lightly at the end of the year when the practical modules have all been put in place by building the final exam rig. The tutors will show you what to do on the testing side but it is only very basic. The level 3 focuses a bit more on the testing and inspection side and will be in more detail.The practical in L2 should be pretty easy , the only thing that caused any issues with my class was the testing part, since we hadn't focused on that much during classes
Disagree. We carried out dead testing on all practical installs. It was a big part of level 2The level 2 focuses very little on the testing aspect and is only touched on very lightly at the end of the year when the practical modules have all been put in place by building the final exam rig. The tutors will show you what to do on the testing side but it is only very basic. The level 3 focuses a bit more on the testing and inspection side and will be in more detail.
It must be a variation in colleges and the one you attended sounds a lot better than mine. Not one singular module was tested at our college only the final level exam 2 rig. I would liked to of seen more testing done during the year as it would certainly of helped the less experienced students.Disagree. We carried out dead testing on all practical installs. It was a big part of level 2
The exam in question is the final practical im assuming. It will entail a full installation from a consumer unit with 4 circuits. Radial, RFC with spur feeding a fcu, 2 way lighting and s.w.a into a commando 16 amp socket. There will be pvc conduit used on the rig and steel conduit plus metal cable tray all of which has to be fabricated, bent and threaded as required and terminated into appropriate accessories like metal clad surface mounted 2 gang sockets. Plastic conduit boxes for the lighting circuits with pvc conduit. All circuits we wired were wired in singles using the appropriate sizes for the circuits. Easily done in allotted timescale and all of which you should of learnt over the previous wiring modules during the year.
Your test rig will be inspected and tested dead and then you will be taught if the tutor passes the rig the live testing process.
Good luck and dont rush it is my advice tutors are there to help you and try and keep it all neat and tidy looking i.e all accessories straight and conduit runs straight and neat.
