deanh20
hi everybody.
My boiler in the caravan keeps coming up with low voltage warning which states that potentially the supply is faulty. I got a plumber out to check boiler and he did a test on the earth to live and got 240v he then tested earth to neutral and got 240v. He said i need to get an electrician in to sort the electrics out which i dont have a problem with however something in my mind does not sit right.
The static has a 10amp supply which has RCD and the static also has its own RCD. Would this not have blown any of the RCD and is this not dangerous.
Any ideas on what could cause this problem as the boiler has been working fine up untill 2 weeks ago.
