Discuss 3 phase advice in the UK Electrical Forum area at ElectriciansForums.net
soulman
Hi, i require a little advice. 3 phase supply (100A per phase) from energy meter into 3 phase switched fuse isolator, then swa off to D.B 20 metres away. Distribution board feeds office equipment only. I need to install a supply for a 36kw 3p machine, which is going to be situated next to intake. My question is, can i tap into the switched fuse isolator, provided i can get my cable in. Then swa to 63A switched fuse to supply machine. I have spoken to 2 sparks & both have gave me different answers.
Any help appreciated.
Really depends what your max demand is on the overall installation (I'm assuming 36kW isn't a typo). If your 100A intake can handle the extra load then yes, although I wouldn't be tapping directly in to the switch fuse, I'd go into a little busbar chamber if I could, worst case scenario if cost is an issue and you can be sure of no more similar additions then tap into a few henley blocks in a nice enclosure.
Edit: beaten to it!
Thanks guys, that's really helpful. This is not my usual sort of work. Max demand is o.k just office equipment, no real loads. I like the idea of henleys in an enclosure. I shall also check out a small busbar chamber.
Reply to 3 phase advice in the UK Electrical Forum area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
