Discuss 3 phase in the Australia area at ElectriciansForums.net
S
stewart1980
hi there i am starting my own company and i have just bought a new tyre machine my unit has single phase but the machine is 3 phase with 4 wires black blue brown yellow and green on the side of motor it has v-220/380 now can i use this in my unit and if so how do i go by doing it please help as losing money now with it not working
Hi Stewart, in short you're out of luck. There are things that can be done to produce 3 phase from single phase but they're highly unlikely to be cost effective at your scale and well beyond giving advice over the web.
Your two best options are 1) see if you can replace it for a single phase machine and/or 2) talk to your energy supplier / unit management about getting 3ph installed, which won't be cheap either.
Either way, when it comes to wiring anything in, I strongly suggest you get a reputable qualified electrician in to do it for you - have a search here for your area.
What does it say for frequency on the motor plate?
In which case, I take back what I said! If it's only that small, then one of the units that Des suggested may well work for you.
Reply to 3 phase in the Australia area at ElectriciansForums.net
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
