Discuss 3 pirs in series in the UK Electrical Forum area at ElectriciansForums.net
S
Scottishspark
Hi guys advice needed
i am on a job where there are going to be 3 pirs controlling around 12 lights the 3 pirs are just because of the layout of the room,these have to be wired through greggs this is a method I have never used before as have been doing heavy industry for past few years
can anyone advise me on how to do this?
many thanks
Cheers guys for the quick replys
leesparkykent how do I wire that?
i know it's a stupid question probs but as I say no done lights etc for years
We all knew it was going to happen, don't think I had much chance of it not, hopefully the OP has a sense of humour, could we get back on track please and give the OP some constructive advice :)
Scotty, as with wiring a simple light controlled by a PIR with a 3 core core between a fitting or joint box, an accessible one of course, I'd just loop a 3 core from PIR to PIR then to the other PIR, all connections are the same within the PIR, just looping the Line and Neutral across and then returning the Switch wire back, which will be joined in the PIR, depending which one detects movement.
I'd do similar only 3core and earth round the lot..not much cost difference.means you could use any of your flexes as a light or pir or indeed emergency if required
Lovely, but he's got to do it with greggs so he ain't going to be running three core from PIR to PIR is he!
Reply to 3 pirs in series in the UK Electrical Forum area at ElectriciansForums.net
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hi, I had a question in my head that turned out to two and then BANG im confused. I need help with calculation here and explanation to get this...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
