Hi,
been asked to wire 3 x 1.5kw heaters in offices in an old warehouse.
2.5mm radial - 20amp rcbo with 20amp DP switch with flex outlets
That sound about right?
You could demolish the warehouse and relocate the business to warmer climes and have no need for the heater.
There's a lot you could do but I expect, like me, you have a customer on a budget and are trying to give them something that will work, is safe and is compliant.
What you are suggesting appears to fit those criteria.
That’s what I was thinking
But I think I’ll just go for 4mm radial with 13amp switched fused Spurs at each heater
Scotland
3 x 1.5kw heaters on one circuit
Mabro22,
Wilko,
