Ignore the question my badWhat Voltage are you using?
That’s what I was thinkingYou could demolish the warehouse and relocate the business to warmer climes and have no need for the heater.
There's a lot you could do but I expect, like me, you have a customer on a budget and are trying to give them something that will work, is safe and is compliant.
What you are suggesting appears to fit those criteria.
The invoice for the design consultation will follow shortly.That’s what I was thinking
But I think I’ll just go for 4mm radial with 13amp switched fused Spurs at each heater
Haha thanksThe invoice for the design consultation will follow shortly.![]()
Has the heating requirements been calculated properly?
you may find that 3 x 1kW heaters would be enough.....
or..... you need something like 3 x 2.5kW!
Why a 4mm RFC? it is a recommendation that loads of > 2KW have their own dedicated circuit, IMO a 4mm RFC is the wrong solution.not exactly calculated, but as I’m installing a 4mm ring circuit, I’ll probs upgrade to 2kw heaters
