put it on a 32A MCB, 6mm cable, 45A cooker isolator. then a 4mm butyl flex to the heater.
Hi,
How quickly do you want the 100l or 300L heated and over what temprature range?
Hi,
We're only heating 100l at a time but even with the 3kw heater it will take around 2 hours just to get to 80 degrees.
We'll probably have to do this at least twice every time so anything slower would take too long.
which side of manchester are you. the west and south is just on my patch.
If go for an isolator and a separate supply myself.
Cooler isolator be ideal and correct overload protection (fuse or mcb)
Sent from my iPhone using Tapatalk
I might be teaching you to suck eggs here, but have you explored gas burner systems ? I believe they can be quite popular with large batch homebrewers so it might work for you ?
I know my local garage based microbrewer manages on a single 3kW immersion heater for his 150l batches but have no idea of his heating times or if his needs are similar to yours.
Are you a fellow home brewer Andy? I have a system half built in the garage at the moment.
I do a little bit but only kits with the occasional batch of cider or ginger beer or similar. Not got the time or space for grain brewing unfortunately. I think I've seen your setup on one of the brewing forums in all its shiny glory.
I am stuck with buying my proper beer from a local guy who brews in his garage and supplies local bars and restaurants. But that's great really as his prices are good, his beer is delicious, and he does 7 different styles currently.
3kw Heater on a 13a Socket
Adskee,
Andy78,
