Discuss 400 v & 230v circuits in the UK Electrical Forum area at ElectriciansForums.net
is this Db a submain? Then rewire it with a new (swa?) with a neutral. I have converted 3 phase boards to single phase using a conversion kit, but there was a neutral there. No neutral = no chance. Unusual set up for a db though to be honest.
exactly thankyou...... i am havin a debait with a freind and you answered my question for me........
cheers lads...
was debaiting that in old typ of supply that becasuse the 3 phases are delta are 120 deggrees out of phase with each other , thaat you could put a single phase circuit on the said system, with out a neutral?????
old type of supply?
3 phase is still 120 degrees apart!
I have just posted on your other thread having just read it.
I suggest you calm down, take a deep breath and think for a moment, then try to articulate, starting from the beginning, what you have in front of you, and what you want to achieve at the end of it.
Breathe, now, breathe....
Reply to 400 v & 230v circuits in the UK Electrical Forum area at ElectriciansForums.net
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
