- Reaction score
- 8,198
Discuss A bit of screwdriver porno in the Electrical Tools and Products area at ElectriciansForums.net
Screwdrivers have been on my mind recently (I don't get out much)
Is it just me, or are most of the 4-5mm flat blades ones too thick for some faceplate screws?
Maybe it's the cheap accessories I've run across, but the medium slotted blade (4-5mm blade width) ones in the (mostly cheap) sets I've tried are often just slightly too thick to work, and the smaller one fits but is too narrow to get a good purchase.
Many of the blades seem to be 1.0 x 4mm - I bought an 0.8 thickness 4mm one which worked perfectly, so of course I immediately misplaced it...
Ohhh Matron. . .
i have a perfect bit in my impact driver, specially for long faceplate screws that need 20 turns.Stanley do a 4mm that's perfect for faceplate screws - no idea what thickness that blade is (I'm 30 miles from it at present), but might be a cheap and cheerful option that does exactly what you want.
That's a leckie's hammer Mate the chippie's one has more curved claw, don't try and fool a tool tart Tel
Ah. I've just started using Click for jobs, so that may be why!I use a 4mm Wiha driver, the only accessory screws I have trouble with are the Click ones which don't seem to have a deep enough slot these are always ditched.
probably because the chippie nicked it off a spark.That's a leckie's hammer Mate the chippie's one has more curved claw, don't try and fool a tool tart Tel
Stop it please. I'll have go the tool shops now.View attachment 60920View attachment 60921
I built this set,in 4 and 6mm,added the exras,converters and specials.....then me pal stitched two tool rolls together and modded the strappng...and hey presto,it is identical to the one the Gypsy promised me,in my dream
Reply to A bit of screwdriver porno in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
