Discuss A bit of screwdriver porno in the Electrical Tools and Products area at ElectriciansForums.net
screwdrivers are my weakness , I can’t stop until I have tried them all....:p
(still trying to save up for my own snap-on ratchet , but if the wife catches me buying one it will be a week in the shed for sure)
[automerge]1600373802[/automerge]
I did pick up a gorgeous pair of old Ceka insulated pliers from a boot fair recently for 2 quid.
i also had a bid in for some old ITL tools on fleabay but got out bid so left it,
Screwdrivers have been on my mind recently (I don't get out much)
Is it just me, or are most of the 4-5mm flat blades ones too thick for some faceplate screws?
Maybe it's the cheap accessories I've run across, but the medium slotted blade (4-5mm blade width) ones in the (mostly cheap) sets I've tried are often just slightly too thick to work, and the smaller one fits but is too narrow to get a good purchase.
Many of the blades seem to be 1.0 x 4mm - I bought an 0.8 thickness 4mm one which worked perfectly, so of course I immediately misplaced it...
Stanley do a 4mm that's perfect for faceplate screws - no idea what thickness that blade is (I'm 30 miles from it at present), but might be a cheap and cheerful option that does exactly what you want.
i have a perfect bit in my impact driver, specially for long faceplate screws that need 20 turns.
I have Also noticed this is several brands that , the width of the blade is slightoy ttoo think
although different 3.5 screws seem to have different width slots so it might be a screw issue & not a screwdriver issue
also I was fitting some cheapo white accessories the other week and they came with cross head screws :eek:
I use a 4mm Wiha driver, the only accessory screws I have trouble with are the Click ones which don't seem to have a deep enough slot these are always ditched.
some more tool ----..... a wood butcher's screwdriver.
Turns out I lied.
Stanley part no. 65-413 and is 5.5mm. Just fits into recess of white moulded stuff.
Sort of driver you'd keep for faceplates as the fine blade is a but on the light side for any heavier work.
View attachment 60920View attachment 60921 :)
I built this set,in 4 and 6mm,added the exras,converters and specials.....then me pal stitched two tool rolls together and modded the strappng...and hey presto,it is identical to the one the Gypsy promised me,in my dream ;)
Stop it please. I'll have go the tool shops now.
Reply to A bit of screwdriver porno in the Electrical Tools and Products area at ElectriciansForums.net
This week at Electrical2Go we have a selection of NightSearcher products that are over 50% off! We even have a selection of NightSearcher Kanga...
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
I’ve a brand new set of these Klein Screwdrivers for sale: Klein Tools 33736INS Klein Tools 33736INS Insulated Screwdriver Set, 1000V Slim-Tip...
We have got some other sections of the forum that I thought might be useful to you guys! They are for all countries but we have new tags that you...
Aside from every screwdriver in the universe, I wonder what the most creative mis-use of a tool you have encountered is. I'm sure this example can...
4K
