sparks1973
well you can use whatever`s appropriate for the scenario...be it wago`s, crimps or blocks.....
Discuss A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
So how do you get them out of the wago push ins, and where is the testing point? , I'm not questioning it , I am just trying to persuade myself to use them!!!
Hold the cable to be removed in one hand and the connector in the other, then twist the connector about 90 degrees cw/ccw while constantly pulling on the cable. After a few seconds it will release with a nice "toothed" pattern on the conductor, but no damage done. If you look carefully, you will see a small hole which can be accessed by a fine probe tip for testing purposes.
Once you've used them, along with a LIneProducts enclosure, you'll never use a round JB again. Line also do the connectors which are no different to wago (just a tad cheaper).
Oh, and don't forget Line do a proper, compliant MF kit which is the bees knees and spider's ankles
whats the manufacturer's notes of yanking a cable out of a push in,is it reusable after that and how many times do they recommend the yanking/forcing out method before replacing the connector
well i think the jury`s still out on wether their maintanence free or not RauerSo with an appropriate enclosure are wagos classed as mf? And is the line enclosure mf when linked with the wagos? ( I hate typing wago's!- I'm sure anyone with an iPad will agree! It makes me very hungry for wagon wheels!)
I don't believe it does the wago or cable any harm, and more than operating a spring does. That said, if I have a situation I know will require dismantling then I simply use the lever types.
For the record, no need to yank.
I think Line connectors say they are one use only, once you try to remove the cable they are no longer usable, Wago does not state how many times, but do say they can be reused as far as I remember.whats the manufacturer's notes of yanking a cable out of a push in,is it reusable after that and how many times do they recommend the yanking/forcing out method before replacing the connector
Not quite true, as if the maker states they are maintenance free then this is fine as far as the regs go.
Manufacturers instructions and all that!
The MF logo is just a situation of confirmation.
If you bend a piece of metal enough times it will fatigue and lose spring. Push-ins are reusable (but if you yank out bin them) but don't over do it. I personally bin them after a few uses.
I'm amazed how many contributors use variations on the theme of "Screwits". I avoided them like the plague when I was doing regular work as a sparky and now that I'm looking at coming back into the trade I'm quite worried by the many interpretations there are of "Maintenance free" and hence the use of such connectors.
LOL a mate of mine worked out in Libya where it was shocking the spark they sent out there came back after a week in 18 months there were several fires, electrocutions and some horrific potential accidents.For the record, this was not discovered in the UK.
It was found on a military camp which is supposed to be British Standard!
They are a load of rubbish.
They are lazy, also I cant imagine you would be able to get your test probes on them. And what is the target market? They are bigger than crimps, connector blocks, and push fit connectors, all of which are more suitable. You cant put them under the floor or in a place where they cant be maintained. Only time you might use them is for a light switch which has the feed going to it, which also is rubbish as 3 plating everything is better wiring method.
On a new install you shouldnt need them, should use junction boxes and connector blocks behind switches and in light fittings.
Are they even value for money?
Reply to A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
