Discuss a Synchronism check relay in the Canada area at ElectriciansForums.net
B
bejoyengineer
I am not sure how a Synchronism check relay works? Any good sites with explanations would be of great help….. As the name and description given in manuals, it states that this relay checks the voltage, magnitude, phase angle and frequency between the lines connected to the in and out of a breaker that is ready for a close operation or in other words it checks the voltages between the incoming line (line going to the breaker) and the bus( the part that is going out of the breaker and connected to the bus). But in the actual case –only the incoming line to the breaker will be hot and the outgoing line from the breaker to bus will not be hot and will become hot only if we close the breaker. So in that case – how will it actually compare the voltage, magnitude, phase angle and frequency as we have a live line and a dead bus condition all the time and there by closing the breaker? When and Where does the comparison take place?
Reply to a Synchronism check relay in the Canada area at ElectriciansForums.net
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
I'm taking a look at the 120v wiring in an old travel trailer that I recently bought, and plan to live in full time soon. It has some quirks that...
