Hi,
I've recently had solar PV installed alongside a Myenergi Eddi diverter for the immersion heater.
I have a large 450 litre thermal store but the immersion is already maxing out as it's a third of the way down the tank, but as it's an indirect tank it has a heat exchanger on the side which when you call for hot water at the taps a PCB monitors the cold water flowing through the heat exchanger and calls for a 80w pump to push hot water from the tank into the heat exchanger - stop the taps - it then has a small delay on stopping to refill the heat exchanger for next use.
The heat exchange return pipe for the "used" hot water is close to the bottom of the tank - so I was thinking is it possible to split what I have to provide power through to the pump which would then allow the PCB to work as normal but also on sunny days push the hot water from the immersion down into the bottom of the tank therefore restarting the immersion heater?
This circuit is continuous power 3 core cable -> wired into PCB -> wired out from PCB to pump
(the PCB has three temp sensors - one for the top of the tank to know if it's got hot water - 1 on the cold water inlet - 1 on the hot water outlet - it uses the temp difference to alternate the power going to the pump)
Is it possible this could work to...
One side becomes -> continuous power 3 core cable in -> split cable in Wago 3 way (1 in 2 out) -> wired into PCB -> wired out to Wago 3 way (2 in 1 out) -> wired to pump
Other side becomes -> continuous power 3 core cable in -> split cable in Wago 3 way (1 in 2 out) -> wired into thermostat 1 top of tank (reversed eg temp =>75c complete circuit)-> wired into thermostat 2 pipe stat on bottom (calling for heat) -> wired out to Wago 3 way (2 in 1 out) -> wired out to pump
I think this isolates each side from each other - just want to make sure I don't fry the PCB - any advice welcome.
Thanks,
Niall
TBH I'm finding it a little difficult to imagine the electrical schematic from your narrative - sorry!
Did you know there's a suggestion for implementing "de-stratification" on the Eddi website - not sure if it relates to the exact PCB you have?
I see the PCB has 'volt-free' contacts, so you should be OK if you stick to those, and don't present contacts with excessive load! The PCB doesn't appear to use solid state switches, which could be more problematic
I see the PCB has 'volt-free' contacts, so you should be OK if you stick to those, and don't present contacts with excessive load! The PCB doesn't appear to use solid state switches, which could be more problemT
Thanks Avo - it's took a while for me to think about it as well! But your solution of using the Eddi would simply the wiring and do exactly what I need.
Hopefully to simplify I have a stratification pump in place with an existing supply (that I can't turn off because it's needed everytime we use hot water activated by PCB) assume this is on the upstairs wall sockets circuit.
The Eddi's power comes from the immersion heater cable.
How do I join each of them (safely) to the pump? I'm just concerned that I'll short something or the blow the PCB apart or have both supplying power at the same time.
Many Thanks Niall
Sorry I'm still having difficulty as I'm not very familiar with the Eddi!
What is the 'signal' that should switch your stratification pump on?
Is it one of the PCB relay contacts, or is it the presence of power on the immersion heater? The latter would be a problem as the Eddi adjusts immersion power by phase control of the available ac, and that might not be reliable to drive a simple mains relay.
If your stratification pump is separate from the 80W circulation pump you mention, and powered by a different mains circuit, you need a relay to interface the two.
The coil driven from mains via the Eddi PCB, and the NO and C contacts connected across whatever switches the stratification pump.
Just an example, but not necessarily a recommendation:
As an Amazon Associate we earn from qualifying purchases.
I have a suggestion.
Presumably, the immersion heater gets turned off by an internal thermostat when the store is up to temperature. Take two wires off either side of the stat*, and take them to a relay coil - when the immersion turns off on the stat and power is still applied, the relay will pull in.
The relay needs to be 2PCO (2 pole, changeover contacts). Wire the common to the existing pump, NC contacts to the output of the existing controller, and the NO contacts to the supply to the existing controller.
What this will do is: power is applied to the immersion. When the store gets hot and the stat opens, the immersion supply will be applied to the relay coil (the immersion heater will just act as a very low resistance relative to the relay coil). When the relay operates, it will run the pump until the immersion stat closes again, or the immersion supply is turned off. Whenever the immersion circuit is not driving the pump, it will operate as normal as required by the DHW system.
Depending on the internals of the existing controller, it may well be OK to just use a SPNO relay and connect it between supply L and pump output L.
Also, it may well be worth using a run on timer (delay off) relay so that if (for example) the supply to the immersion is pulsed or otherwise regulated to match a partial solar output level, you don't get a lot of stop-start operation of the pump.
* If the thermostat has C/O contacts, put the supply to common, and use the "close on rising temp" contact to supply the pump relay.
The thing I was concerned about is that the Eddi "VariSine" technology controls the immersion through PWM of the supply to it, over the range 100W to 3kW. So the Eddi may be supplying a significantly chopped waveform of modest voltage (I've just established it's about 43.8V RMS at 100W) that might not pull in the suggested relay, or might make it chatter and have a limited life! Maybe I'm being over cautious, because it's not necessarily "mains" voltage at the immersion heater, so I thought if there was an alternative 'signal' available, that would be preferable?
OK, in that case, an electronic timer relay. Power needs to come from upstream of the PWM controller, and the trigger from the output.
Unless the stat is changeover, relay L goes to immersion N, relay N to to PWM controller supply L, and trigger from connection between stat and immersion. That means the trigger for thecrelay is the voltage across the stat when it's open.
44V RMS will actually be somewhat higher peak. If you check the specs, some of the timer relays have relatively modest thresholds - so I wouldn't be surprised to find them triggering reliably at very low power levels.
