Longshanksy
Hi,
I've recently had solar PV installed alongside a Myenergi Eddi diverter for the immersion heater.
I have a large 450 litre thermal store but the immersion is already maxing out as it's a third of the way down the tank, but as it's an indirect tank it has a heat exchanger on the side which when you call for hot water at the taps a PCB monitors the cold water flowing through the heat exchanger and calls for a 80w pump to push hot water from the tank into the heat exchanger - stop the taps - it then has a small delay on stopping to refill the heat exchanger for next use.
The heat exchange return pipe for the "used" hot water is close to the bottom of the tank - so I was thinking is it possible to split what I have to provide power through to the pump which would then allow the PCB to work as normal but also on sunny days push the hot water from the immersion down into the bottom of the tank therefore restarting the immersion heater?
This circuit is continuous power 3 core cable -> wired into PCB -> wired out from PCB to pump
(the PCB has three temp sensors - one for the top of the tank to know if it's got hot water - 1 on the cold water inlet - 1 on the hot water outlet - it uses the temp difference to alternate the power going to the pump)
Is it possible this could work to...
One side becomes -> continuous power 3 core cable in -> split cable in Wago 3 way (1 in 2 out) -> wired into PCB -> wired out to Wago 3 way (2 in 1 out) -> wired to pump
Other side becomes -> continuous power 3 core cable in -> split cable in Wago 3 way (1 in 2 out) -> wired into thermostat 1 top of tank (reversed eg temp =>75c complete circuit)-> wired into thermostat 2 pipe stat on bottom (calling for heat) -> wired out to Wago 3 way (2 in 1 out) -> wired out to pump
I think this isolates each side from each other - just want to make sure I don't fry the PCB - any advice welcome.
Thanks,
Niall
Thanks,
Niall
