sundanceuiuc
Hello, and thanks for your help in advance.
For a client's minor renovation, they purchased this fixture:
View: https://www.amazon.com/KWOKING-Lighting-Acrylic-Dimmable-Adjustable/dp/B0895R4ZTV/ref=sr_1_7?crid=14YQTN3SSKAXL&dchild=1&keywords=kwoking+lighting+modern+ceiling+light+and+fan&qid=1601158957&sprefix=kwoking%2Caps%2C192&sr=8-7
It was advertised as having color control, and this is technically true, but other lights have a switch on the fixture for control, and this has a remote that requires the light to be changed every time it is on.
It defaults to 5000k and it has to be turned off, turned on to 4k, turned off, turned on to 3k (to match the other down lights in the 2700-3000k).
Is there a way to add a switch to make it default to 3k? Otherwise the 5 clicks each time makes it unsuitable.
Any ideas are welcome with my thanks!
SD
SD
- TL;DR
- Aftermarket control for LED lamp to force 3k default
As an Amazon Associate we earn from qualifying purchases.
