Discuss Advice on installing LED strip lighting in the DIY Electrical Advice area at ElectriciansForums.net
roboto
Hi guys, DIYer here hoping for some help and advice. I am redoing my kitchen and plan to put a 5m strip of LED lighting below the units above the plinth.
I want to make this dimmable and connect it with lighting cable to a 3 way light switch (along with existing wall light and undercupboard light switches).
A few things I'd like some advice on:
The strip itself- does this need to be specifically a dimmable one? And can it easily go around a corner? Any recommendations on the best type to go for?
The driver: I understand this is required to lower the voltage to the LED strip. Any idea on what kind I will need for this job? Also, is it easy to connect this to the lighting circuit? The ones I have seen usually have a socket on the end.
The switch: I know this has to be LED compatible. Anything else to be aware of?
I think these 3 things are all I need? If anyone has experience with this kind of thing any help would be much appreciated.
Reply to Advice on installing LED strip lighting in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
