Discuss After a little advice about energenie switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone!
Got somewhat confused with an energenie master/slave switch set today.
The downstairs switch has (I’m sure I don’t need to say but will just in case):
Constant live
L1 (switch)
L2 (switch)
L2 (switch)
This switches on a hall light and stair light.
The upstairs switch is wired as usual - common and switch lives.
The energenie master switch doesn’t seem to make much sense - it uses a slave connection, live, l1, lx and l2
The slave switch uses a slave connection, and also has a line in and out.
The instructions are not particularly clear to follow and wonder if anyone could help? I have no problem getting a qualified electrician to do it, though I’d still like to know how ;)
Hi bud,you are going to struggle,to get a step by step,on this one,as there are other factors to consider,besides the obvious...
What is the depth of the backbox receptacle? if that is insufficient,the rest may have to wait:)
post up a pic of the wiring instructions.
afaik, it's Live into L and sw?L into L1 on master,then a 3core to slave .
file:///C:/Users/tel/Downloads/Master%20Slave%20Spread.pdf
Reply to After a little advice about energenie switches in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
I've got a customer with 2 way switches which I want to rectify it in such a way it would simultaneously control the single light fitting. The...
