Discuss Again the dreaded 18th edition additions...AFDDs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
michaelw6
Ive search the forums and cannot find a conclusive answer.
I have been reading my New Regs Book today (Thank you sam400) and the IET BSI changes within BS7671:2018.
Now it says 'chapter 42 protection against thermal effects:- New regulation 421.1.7 recommending installation of arc fault devices. now when you read this regulation is says as above. The AFDD shall be placed at the origin of the circuit to be protected. Example: Premises with sleeping accommodation.
Now that to me would be a domestic dwelling, yet when i ring wholesalers i just get the reply 'Nobodys fitting them! We have no call for them! or Waiting to hear back from supplier!'
Now when it comes to SPD devices they are being pre fitted into consumer units now, even with type A RCDs.(Hager)
Id like to install Schneider but they dont seem to do anything 18th yet.
My Question is Regs say they need to be fitted. Can you get a main one to cover all or should i just fit them to the lighting and sockets where the bedrooms are? or every circuit?
Not fitted any AFDD's myself yet so what do you guys do and what manufacturers do you use?
The regulations do not say they must be installed, they are only a recommendation,but if installed then they shall be installed at the origin of the circuit that is to be protected, add that to the cost of the product is why nobody is installing them.
I would add that the term sleeping accommodation refers to hotels,HMO’s and the like rather than a domestic dwelling as bs7671 references the term ‘dwellings’ as your typical domestic house
You’d think that someone who can publish a technical document, would also have a reasonable grasp of the English language to phrase descriptions or definitions, so as not to cause a misunderstanding or confusion. Or is that too much of a big ask :cool:
As above, they are a 'recommendation'.
You could give the customer 2 options. One with AFDD's and one without. The one with, stating the advantages of having AFDD's.
Then it is up to the customer to decide.
We had a post about these and John Ward testing them, where he did a rubbish test.
When looking into the details of AFDD's it looks like the current had to be over 2.5A when detecting.
Not sure how what will work out for lighting circuits in modern houses that have all LED lights.
Having spoken to afew electrical engineers about the concept of arc fault circuit interruption, they were all very sceptical about the functionality of these devices.
From what I gather arc fault breakers were introduced into the Nec code due to the amount of extension lead shorts and overload burn outs in America and Canada.
Their leads and plugtops are much more flimsy than ours.
The American electrical supply is 115V single phase with a correspending higher current for the equivalent appliance power rating, so its no surprise that there is a greater chance of the need for a method of arc detection.
I think that once the manufacturers have got to grips with the risks involved in this country where the likelihood is actually quite small compared to other factors then the designs of protective devices may have combined functionality such as RCBO with SPD and AFDD. Until then the regs only recommend the use which stands for very little.
Reply to Again the dreaded 18th edition additions...AFDDs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello all Planning to do the 18th edition online. I could just batter loads of old papers on the head and then have an attempt ( I will do loads...
  • Locked
18th 2nd amendment comes in, in Sept. AFDDs are in it. To be fitted on socket circuits of 32A and above. To be fitted in residential blocks of 6...
12K
Does anyone else get emails and phone calls from companies and agencies say we seen your CV and we want you to apply for our job. And when you...
Recently been working on a system design for a LL. I was told the building would be a three floor 16 room HMO, so the design was done to the...
5K
Here we go again, another job that has had a council inspection, different council to last time but still perplexing. The problem with these jobs...
