And mean while Croppie back in the real world..........
In the real world you're wrong, and you have neither the wit nor the wherewithal to realise it.
At the end of the day, it's my house, my boiler and I'll do what I like with it, wouldn't be the first time I've repaired it, won't be the last (electrically)
Were not talking about me going out fixing other people's boilers playing about with gas ect, I'll take the risks with my own home.
I sincerely hope you don't cock it up and your family doesn't end up dead cold.
Here we go, this is why I don't use forums, now my whole family is going to end up dead because I've tried to cure a fault without testing the circuit and by removing the cover from a boiler, I don't think so. I'm sure many electricians have done without being gas compitent) I have changed the RCBO the fault no longer occurs, if the cable or the boiler was still faulty it would be tripping the new RCBO.
Where has the electric shower came into it?
I shall no longer be participating in this thread, for those who actually contributed to the fault, I appreciate your reply.
so your saying a non part p in your eyes can change a consumer unit / add an elec shower to the existing set up and you say this is ok as its the real world
Rightly or wrongly Electricians all over the country everyday of the week wire up heating systems/boilers. Some of the biggest firms out there like BG and help-link send electricians to wire their heating systems and have to remove the cover to do so without wet pants being there.......So yes in the real world it happens. And yes they could but as its notifiable then they would have to get someone who's allowed to do third party inspection & testing / notifications or notify building control before hand and pay the fee for them to send some one to do it on their behalf.
Don't worry about it mate and don't let that numpty put you off using the forum :)
false as the sparky only wires a fused spur in and the gas safe eng comes along when fitting the boiler to wire up if hes not part p but tbh most theses days are
and good luck trying to get someone to test and pass someone else's work off :D like you phoning me up and asking me to write you a form out to say the gas pipe you installed is correct and safe
Only one numpty on here pal, and that's the one who cannot comprehend different competencies.
I don't get involved in wiring distribution boards. That's not where my skill set lies. I defer to you guys for that.
You don't have the knowledge and experience to open a boiler according to the gas regs. But because your head is so far up your own bottom you presume you do.
Hum..... A 2nd year apprentice who owns a house. Lucky you!
@Corbs its not false I know 3 electricians who work for help-link and two that work for BG. And they don't need luck to legally change a consumer unit just a fat check to building control.
Quote from http://www.legislation.gov.uk/uksi/1998/2451/made
"(6) Nothing in these Regulations shall apply in relation to—
(a)the supply of gas to the propulsion system of any vehicle or to any gas fitting forming part of such propulsion system;
(b)the supply of gas to, or anything done in respect of, a bunsen burner used in an educational establishment; or
(c)work in relation to a control device on a gas appliance if—
(i)the device is intended primarily for use by a consumer of gas; and
(ii)the work does not involve breaking into a gasway."
Does that regulation not allow electrically skilled persons who are competant to work and remove the cover to fit controls???????
Yes Croppie that would be too complicated for you ;).
No. 99% of boilers these days actually use the case as a combustion seal.
Being electrically skilled I'm afraid doesn't make you competent in this instance.
please read
https://www.---------------.co.uk/media/1449/who-can-legally-work-on-a-gas-appliance-factsheet.pdf
but does the original / a gas safe engy go back and commission and turn the gas on think you will find they do, or they will do the work while the gas safe eng is there as normally sent in two man teams
No wetpants installs the boiler and runs it up/commissions it off a plug top. Electrician goes in maybe that afternoon or sometimes a few days later an wires boiler/controls. wet pants doesn't return to site.
