Rocboni
- Reaction score
- 145
Having a few issues with our alpha boiler 4years old, had a bit of bother with it last year in the back end towards summer, no issues over summer months, now the cold weather has started, its started tripping again. Then again no heating has been on over the summer!
Recent consumer unit change, from old dorman smith series 17 with dual RCD, never had any issues with it tripping those.
The boiler is virtually right next to the consumer unit,16A rcbo 2.5mm twin and earth down the back of the wall behind C/U under the floor and back up clipped direct into a FCU, flex out to boiler, 3 amp fuse. Cable insulation test is clear.
Controls are wireless so no faults with control wiring.
The boiler does not drip when firing up, having a shower ect, we usually just go to the tap and have no hot water, to find RCD tripped.
Has anyone had similar issues, read a few post regarding condensation dripping into flue stat?
