T
thekingiam
Just read a blog stating all cu in domestic to be fire retardent is this true and does that mean all cu to be metal
January 2016 is the date for this. More worryingly is the requirement for all cable entry points to be fire retardant too so this is going to be expensive.
this was covered by the NICEIC at elex last week and I asked if a smoke alarm could be installed in the location of the cu instead - which I thought was a perfectly reasonable idea but Tony Cable didn't
Does that mean another amendment 12 months later then?January 2016 is the date for this. More worryingly is the requirement for all cable entry points to be fire retardant too so this is going to be
how?January 2016 is the date for this. More worryingly is the requirement for all cable entry points to be fire retardant too so this is going to be expensive.
they have 20mm knockouts or a 20mm wholesaw and stuffing glandsWhat are the statistics then on houses burning down due to new modern plastic consumer units? Metal consumer units will be a pain in the --- trying to cut out for cable entry etc
or if there are a lot of cables, backbox in wall, gunk it up then end back of consumer unit
Apparently there has been an increase in CU fires in the UK over the last few years.
Wouldn't surprise me to find that it's due to these so called 17th edition boards.
