HappyHippyDad
Supporter
I would like a lightweight electric implement for undoing and doing up screws on sockets, switches etc. It's really just for when I am doing EICR's as you take off quite a few faceplates. There are so many options out there that i'm getting a bit snowed under trying to narrow down my search. It's really if any of you use something like this and are happy with it.
Ideally i'd like it to have a degree of speed control on it, although I guess if it is pretty slow anyway then maybe not. Anything from some kind of pencil screwdriver to one that looks like a drill, as long as it's light.
Cheers :)
How much do you want to spend?
I don't really mind Pete. I like to buy quality so it can be a bit pricey (let's say max £150), although if there's something cheaper that does the job then that's fine.
I have one that I got in the states. Best way to describe it would be like a tiny wheel brace with a 4mm flat end and a handle that spins. Maybe some of our members from that side of the pond will know it’s correct name. What I do know is that it is a doddle for socket screws.
i have a cheapo ryobi. 4.0V has speed control and torque control. ideal for what you want. bosch and a few others do similar.
The WIHA one is nice but above the price range you quoted about 260 scrots
Bosch go. Mine was £30. Brilliant
I looked closely at that one but was really put off by the fact that you have to push the screwdriver forwards to make it work, rather than a button.
The wiha certainly does look good Pete. I know I said price doesn't really matter but that is perhaps a little too much :)
go for the ryobi. £20. it's a no brainer. had mine 4 years. was £30 when i bought it.
I'm really looking at the wiha. It does look really nice!
Nope.. decided against the Wiha, it's just too expensive. It also may have a design flaw in the o ring that holds the bit in place, plus Wiha customer service sounds poor, so not worth the £200.
