Thats what I am thinkingDon't most socket plates come with 2 earth terminals these days?
I'm sure the ones we spec do.
Some do, some don't.Don't most socket plates come with 2 earth terminals these days?
Also the back-box terminals are often smaller so harder to get 3 wires in to make it worth doing, let along 4 as a common point
MK sockets, just one entry for each wire, earths in the middle. https://forum.buildhub.org.uk/uploa...dium.jpg.2847134c6b9eab17346eb6ad1c7cdd10.jpgDon't most socket plates come with 2 earth terminals these days?
They're garbage.
It's the MK Logic Plus DP's that i've been using. Only one terminal for each wireTheir DP socket has a 2nd earth terminal.
I actually prefer the look of those, will probably grab some of them in future.Turns out they are DP - I'd long thought K2747 was SP.
Anyway, K2746 (with outboard rockers) will have 2 earth terminals.
The only issue I have with MK accessories is that terminal entries aren't 5.5mm flat blade friendly.
I think those were the ones intended for "high intergity" earthing for IT use (RFC or looped CPC with separate terminals for eacy connection so loose screw only breaks loop, not allowing anything to be CPC-free), as well as lower risk from accidentally switching off to loads by mistake. Cost a bit more though.Anyway, K2746 (with outboard rockers) will have 2 earth terminals.
Hi what do you mean by IT? Racking my brain here and can't think what you mean.I think those were the ones intended for "high intergity" earthing for IT use (RFC or looped CPC with separate terminals for eacy connection so loose screw only breaks loop, not allowing anything to be CPC-free), as well as lower risk from accidentally switching off to loads by mistake. Cost a bit more though.
The MK sockets with Wago-style clamps look interesting, got one somewhere but not actually used it yet!
Lol you're not using them?Got a couple of boxes myself and they're great at taking up shelf space.
