as title, is anyone using them, just that on the guidance for recipients at the bottom it actually says you should recieve a seperate mwc for each circuit worked on but yet this mwc is supposed to be for upto 3 circuits, i know its not much of a problem but i can see at some point a customer reading it and asking why they only have 1 cert if you have worked on more than 1 circuit, i have edited it and took out seperate, which makes it less confusing to whoever is reading it is this allowed would you say, you would of thought elecsa would of altered this to suit the cert cheers
