Discuss anyone using elecsa upto 3 circuits mwc in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
crow11
as title, is anyone using them, just that on the guidance for recipients at the bottom it actually says you should recieve a seperate mwc for each circuit worked on but yet this mwc is supposed to be for upto 3 circuits, i know its not much of a problem but i can see at some point a customer reading it and asking why they only have 1 cert if you have worked on more than 1 circuit, i have edited it and took out seperate, which makes it less confusing to whoever is reading it is this allowed would you say, you would of thought elecsa would of altered this to suit the cert cheers
Reply to anyone using elecsa upto 3 circuits mwc in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
