T
Toneyz
I have been asked via a PM jobs advertised for a approved electrician I believe its a term that was used years ago referring to electricians that had some experience behind them, may be some of you could explain better than me and what it means when advertised for today.
Used to be over 25 with C&G B certificate I think, was a while ago the C cert gave you Technician, again I think that was how it was. Now I think what you mean is an Approved contractor, what that means well your guess is as good as mine, something to do with scams I believe. But what do I know? I'm retired so to some my input don't matter. You know who you are.
JIB Grading - https://www.ecscard.org.uk/jib-grading.aspx
Approved Grade
The Approved Grade shows the cardholder has achieved the Core Grade and, after at least two years’ experience, has taken up additional responsibilities as required by the Approved Grade recognition.
There is additional training required to progress to the Approved Grade. Depending on the Core Grade, this is usually a qualification in Initial Verification and Periodic Inspection & Testing. Qualifications are dependent on the duties of the job role that the Approved Grade requires.
Nothing to do with scams pete unless you also consider the JIB a scam as well?
(Many do by the way)
Thanks Pete I think you were on the right track of an explanation in your first part of reply I am not referring to the NICEIC Approved contractors scheme.
Approved Electrician
Toneyz,
Pete999,
