Discuss aurora led sunken spotlights in the UK Electrical Forum area at ElectriciansForums.net
F
fulla
hi guys just wondering if anyone has had experience with the new aurora led sunken spotlights, they are sealed units and supposed to be guaranteed for 5 years, i fitted 8 in a kitchen the other month and 3 of them have now failed all at different times, the wholesaler does not keep them as stock items so i have to go back and disconnect the faulty unit and revisit to install new one oh and they don't just go out they strobe like a disco light
hi , they driver may be faulty? but personally i wouldnt use aurora Light lights in the past they have failed on me ! i use a company called bri-tek and go direct , they have never failed on me and their lumen output is far better and the prices are much better i mainly specialise in LED Lighting and i have not had a single problem with them
We Use Aurora lights alot and have never had any problems with any of them TBH. Were they fitted as per the manufacturer's instructions? Do they have the correct free air distance around them? If so then if you were to goto Aurora direct then I am sure they would help you out.
We don't use aurora fittings (not for any bad reasons, we just use different ones) but we've found that, for floodlights/streetlights/corn lamps, it's better to have a separate driver and LED combination for reliability. Guess it's down to the electronics running that little bit cooler but it has made a difference on the number of call backs we get.
ps Sorry to the OP for a slightly off topic ramble...
Reply to aurora led sunken spotlights in the UK Electrical Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Good afternoon! I've recently wired a lighting system, where one light switch (a motion sensor) turns on two lights, but another motion sensor...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, I have moved into a house with a huge kitchen which has 12 Luxna spotlights about 3 years ago. Over time the spotlights have been failing...
Hi I've just moved into a flat and it has old brass downlights in every room, I also think a lot of them are halogen and not led so keen to...
