Discuss automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
I have the CK automatic ones and love them. Don't use them for twin but they save me loads of time when making up flex leads for downlights etc.
I do have a pair of these Knipex in my bag that have never been used:
ck croppers save me loads of time, especially on singles. I use nws side cutters for twin n earth for board changes, as they cut the outer sheath clean and straight.
Had automatic wire strippers, never used and gave them away.
i find these perfect from RS 157-0875
strip wire from .2mm - 6mm
there no adjusting or anything just pop the cable in and away you go.
£12
Dave
£12
Dave
I use a pair of these as well and find them very easy to use, especially in tight spaces. Not so good on 4 or 6mm cable though as it is a bit of a faf to get the cable into the jaws so revert to snips in those cases.
hey sorry i not replied
i was after some automatic stripers as
at college a while back i saw some one blitzing through 2.5 t&e for a assessment
the cutters cut the sheathing nice and straight
they then strip the inner cable without nicking the copper
the chap using them flew through the ring he was doing with no negative feed back regarding his t&w
all cuts were straight and neat
shame he failed as he didnt run a continuos earth in his lighting for some reason :S
Hello all (we are a sponsor advertiser so we are posting here but its not spam) please look at our scrap cable wire strippers at WS 200 ® UK Automatic Wire Stripper Tool, Don't Scrap it, Strip it! -...
clean copper wire or pipe £4.70/kg stripped
cable with insulation on £2.00/kg unstripped
Many Thanks Joe
Have a look at these mate.They are about £10 ex vat.All electrical wholesalers should stock them.I wouldn't use them personally.Hope this helps thou;)
Cable tooling specialist for tools, crimpers & cutters for the electrical industry
I had a pair like that. little farkers broke on me stripping 2.5mm 3 core despite them claiming to strip up to 6mm. also said from 0.2-6mm iirc. it was crap on anything that small.
now I do the same as OilBeDamned. snips up to 2.5mm, Stanley for anything over
Reply to automatic wire strippers in the Electrical Tools and Products area at ElectriciansForums.net
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
Hi guys Can anyone recommened a decent cable stripper for flat and 3 core cables? Here's a couple ove seen online...
My friend has got one of those robot lawnmowers that automatically goes out once a day and runs around the grass. There is a single core guide...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
Hi, agricultural off grid project, Victron inverter/charger, BYD LVS and Pramac GBW22P generator. The generator has a DSE4520 controller...
