Discuss Bathroom extractor fan to light switch in the UK Electrical Forum area at ElectriciansForums.net
Hi all, wonder if someone can help me.
I've bought a bathroom extractor and I do have the wiring there already (previous extractor was there) but I stupidly did not review it before taking it off and now I'm lost.
I've essentially got a single light switch outside the bathroom which controlled extractor and light. Timer stayed on for 10 mins after light was off.
I have the Live and Neutral in for light switch.
Live, Neutral and Earth for junction box on the light.
3 core for the extractor.
How do i connect it? Or should I get a spark?
I was told a fused spur isn't necessary (saves me a lot of hassle as fully decorated)
Thanks!
Thanks!
Because it's a timed fan, there will be a switched live from the light switch and a permanent live for the timer part, along with neutral and earth.
Reply to Bathroom extractor fan to light switch in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
