Discuss Bathroom fan and light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
ian hall
If you had to change a bathroom light fitting for another (assume correct zone rating) and had to fit an extractor fan(230v)at the same time, would you fit an rcd. Seems to me it,s try and fit an rcbo or an rcd spur or none of the above!!! Obviously the bathroom firm want the lowest invoice possible.
Ian
I would allways have fitted a 3 pole fan isolator it just seems alien fitting an rcd for a fan!
The Niceic say that an rcd would not be needed if the light fitting "only" were being changed but the new wiring for the fan will need a minor works which in turn will require an rcd. All agree with that?
Ian
So, what do you reckon. Alter the wiring and put an rcd spur in the airing cupboard to cover lights and fan. That would also be means of isolation for the fan ie no need for a 3 pole.
either do what you just said or fit a tp fan isolator and change the mcb for a rcbo, whichever is cheapest and easiest if thats what the customer wants
You will need to fit a 3 pole isolation switch if the fan has a tmer fitted so that you can isolate the feed, switch wire & the neutral . If you are just fitting a fan without run on timer do it as you said.
Does not matter if it has a run on timer or not should fit an isolater next to it anyway.
Besides all of that if you are going to work on the fan you should isolate it at the DB before commencing any work.
The rcd spur would isolate the fan too.
Not if its a timer fan , as you have to take permanent L , RCD fuse spare will be fine on a standard fan , but you will need to put in a fan isolator sw as well as RCD protection if you are fitting a timer/humidistat fan .
Ste :)
Crossed wires!!!!
The feed would go into the spur then to the light-regular 3 plate connection/timer fan. So all is controlled by spur. Probably best to fit 3 pole too though in case they want light but not the fan
Reply to Bathroom fan and light in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
